Progressive Cavity Pump
Hi Everyone,
I would like to ask about progressive cavity pump rotor. Per my client specification it stated Rotating elements shall be balanced per ISO 1940-1 Grade G2.5 but Vendor takes an exception on this requirement due to the design of the equipment.
Is it necessary to balance the rotor of this equipment? your reply is highly appreciated. thanks.
RE: Progressive Cavity Pump
Find somebody how knows and has professional integrity to say what the right decition in your situation would be (and pay him).
Best regards, Morten
Considering the rotating speed for a PC pump should be 300 rpm or less, I really don't know why they'd want G2.5. To me, that sounds like someone insisting on a spec without understanding the application of it.
Progressing (NOT "Progressive") Cavity Pumps turn really slowly (80-400 rpm) and will often have slime an clumps on the rotor. Spending any money post-manufacture verifying balance is a true waste of money.
David Simpson, PE
MuleShoe Engineering
"Belief" is the acceptance of an hypotheses in the absence of data.
"Prejudice" is having an opinion not supported by the preponderance of the data.
"Knowledge" is only found through the accumulation and analysis of data.
The plural of anecdote is not "data"
- ISO 1940-1 G6.3
- WITH PROPRIETARY CLAMPING DEVICE
- PER ISO 14691
- PER ISO 10441
- API 671
I don't know any criteria for choosing one of them. I assumed the selection is based on experience. You are appreciated if giving me any rules of thumbs!
Is your client spec just a generic rotating machinery spec or specific to pc pumps?.if the former as i suspect then you have good reasons for ignoring this. When i bought my first PC pump i thought it was the strangest thing i had ever got hold of, but by God it did a great job empting some well head sumps full of sh1t with not even a cough.
IMO, accept the vendor exception.
This way you don't have to ignore the spec or maybe enter into a one-way argument with your client, especially as the spec. will take precedence.
