Set on nozzle on shell- ASME section VIII Div-2
Design code - ASME Section VIII Div-2
I am searching for the design details of set on nozzle on cylindrical shell.The nozzle is std or non std flange directly welding to shell.refer the attached file.
What is the weld size & reinforcement requirement.any code reference??
can somebody suggest it?
Thanks.
RE: Set on nozzle on shell- ASME section VIII Div-2
Refer Table 4.2.10, Detail 1 (first line). However, you need to correct your weld description (tc=??) to comply with the code.
Cheers,
gr2vessels
Thanx..
Here nozzle is a standard flange(API 6A or BX,..)or a non standard, shape similar to sketch shown in the attachment so what will be the thickness tn??
How to check reinforcement details.?? Whether this can be designed with part-4 or needs to comply with Part-5??
