Multiple Sketch Constraints in NX8.5
Before NX8.5, If you select the control key, the "floating" constraint toolbar stay once you've applied your first constraint. So, you were able to apply more than one constraint
How to do the same in NX8.5 ?
Thanks in advance
Didier Psaltopoulos
http://www.psi-cad.com
RE: Multiple Sketch Constraints in NX8.5
That behavior is no longer supported.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Thank you John for this confirmation, it is what I suspected
Didier Psaltopoulos
