Diamond Rope Cutting - Need for Surface Refinish?
For those of you with diamond rope cutting experience, how much refinishing is required after the cut to use the remaining surface as a floor? Do they have to use surface grinders?
Keep in mind this is an industrial facility - the floor doesn't have to look like a Home Depot concrete floor after it's finished...
-5^2 = -25 ![]()
http://www.eng-tips.com/supportus.cfm
