Rotating about click point NX7.5
Hey guys, I'm new here and hope you can help!
I'm new to NX, but have been using ProE for a few years. I'm running into more of annoyance than a problem and hope you can help.
In ProE you can rotate/orbit/manipulate the model by where you click point is, rather than the centroid or coordinate system center. I know that in NX if I click the middle button, hold for "3" seconds, I can then rotate about where I've clicked. While yes this works, I would rather it be the default. Where if I were to middle click and rotate it would automatically go about where I clicked, not needing to hold for 3 seconds.
Is there any way I can switch to this as the default mode of manipulation?
-Damien
RE: Rotating about click point NX7.5
Hi Damien ,
What NX version you are on? Starting NX8.5 this behavoiur has changed a lot.You may refer to a previous thread for more details.
Best Regards
Kapil
You can set the delay for this in customer defaults ; Gateway - Visualization - View /Screen tab --> there you will find Rotation Point Delay. Try reduce it to 0.
Best regards,
Michaël.
NX7.5.4.4 + TC Unified 8.3
Win 7 64 bit (Intel(R) Xeon(R) CPU X5650 @2.67GHz)
24.0 GB
NVIDIA Quadro 4000 + NVIDIA Tesla C2050
MickyV007 you are the man! That's exactly what I was looking for! I just don't understand why anyone would want this to be the other way. Kapil it's 7.5, but thanks for the effort anyway!
On my SpaceBall I am able to assign a command to one of my buttons to change the view rotation point, if that is what I want.
