Tapped hole pattern bug?
Has anyone experienced the following problem?
I created a tapped hole and then generated a linear pattern with it. I then added a fillet to the egde I selected as one of my pattern directions. Now the holes go the direction I want and the cosmetic thread goes the opposite direction (off the part - floating in space). In my assembly file the screws follow the pattern of the cosmetic threads.
The only solution I have now is to eliminate the fillet. Any other ideas???
RE: Tapped hole pattern bug?
I moved the fillet feature in front of the original hole and the hole pattern and selected edges that are not affected by the fillet and it worked.
BBJT CSWP
