neoprene bearing pad
We received a set of construction documents for a bridge that we are detailing, there is a designation "1/4" neoprene bearing pad (M9.16.2)" referring to a pad below the base plate of the guide rail post. Does anyone know what the M9.16.2 designation means?
RE: neoprene bearing pad
https://www.google.ca/#hl=en&sclient=psy-ab&am...
Its the first link on the above google search...it refers to DOT spec M9.16.2 in the notes
