saving as *,par into *,stl in SOLID EDGE
hi
I would like to save as my solid edge file that is in *,format into stl format but just solid parts are conveted not surfaces.would you plese let me know about this truuble?
RE: saving as *,par into *,stl in SOLID EDGE
STL - Stereo lithography? format for 3D prototyping I believe only supports solids so the routine for export is masking anything that is not supported.
Try exporting a parasolid format file for use in SolidEdge.
Ben Loosli
yes ,STL file that is necessary to make mesh by openfoam as snappy hex mesh. I generated CAD file but i coudnt export all parts except solid ones as STL .
