Correct Toolpath - But Reversed Axis Causes Out Of Stroke Condition
Good Afternoon All,
I have an issue when posting my program.
The tool path is correct, but is posted 180 degrees out.
This is technically correct but puts the machine in an out of stroke condition
This is on a 5 axis machine so there is more than 1 possibility, how do I select a different orientation?
Any help would be much appreciated.
Alan
Alan
RE: Correct Toolpath - But Reversed Axis Causes Out Of Stroke Condition
John Joyce
N.C. Programming Supervisor
Barnes Aerospace, Windsor CT
NX6 & NX7.5
The tilting table real limits were -110°..+110°, but we limit it to -110°..0°. There is no need any user interaction, so there is no errors..
kukelyk
Unfortunately I don’t have access to adjust the post; this was supplied by a 3rd party.
How do I use the ROTATE ude command?
Thanks again
Alan
User Defined Events dialog
From the Events Available list select Rotate
Click Add new event to display the Rotate dialog
Set the Rotation Axis to the desired axis A, B, C
Set the Type to Angle
Enter the Angle
Clicl OK to add the Rotate to the Events Used list.
John Joyce
NX6 & NX7.5
kukelyk
