Refile utility
Refile utility
Can anyone guide me on how to run the refile utility? we just upgraded to 7.5, and are having issues with save as to new revisions or new items, and was told to run a refile utility, but have never ran it.
thanks,
thanks,
RE: Refile utility
For us just saving it after opening it up in NX7.5 was adequate.
I would be interested in hearing why using the refile utility is better.
RE: Refile utility
I ask because there are different versions of the refile utility for native and TC.
www.nxjournaling.com
RE: Refile utility
The refile utility is more important in a Teamcenter environment because once a file has a release status, it cannot be saved by the average user. Now you have a conversion delay every time you open a file, multiplied by the number of users; the wasted time can add up...
RE: Refile utility
I suspect you are having issues with your template parts and those can either be opened and resaved or run the refile utility against them. Look in the UGII directory for refile.exe. If you open a UG command prompt and type refile, it should list the options for the command.
Ben Loosli
RE: Refile utility
RE: Refile utility
Enter refile_part.exe and the help will be displayed for you.
Mark Rief
Product Manager
Siemens PLM
