Array of Parts according to selection
CODE --> CATVBS
Sub CATMain()
Dim ArrayOfParts() 'As Object
Dim ArrayOfParts_size 'As Integer
Dim SelectedPart 'As Object
Dim PartFilt(0)
Set ProdDoc1 = CATIA.ActiveDocument
Set SelectedParts = ProdDoc1.Selection
PartFilt(0) = "Part"
Dim ret
ArrayOfParts_size = -1
SelectedParts.Clear
ret = SelectedParts.SelectElement2(PartFilt, "Select Part", False)
ArrayOfParts_size = ArrayOfParts_size + 1
ReDim Preserve ArrayOfParts(ArrayOfParts_size)
MsgBox TypeName(SelectedParts.Item(1).Value)
MsgBox ArrayOfParts_size
ArrayOfParts(ArrayOfParts_size) = SelectedParts.Item(1).Value
End Sub
Hello everyone
I've got problem with filling array of parts -see code below.
Macro stops at error on line:
"Object doesn't support this property or method"
is it even possible to create array of Part object's type?
LukaszSz. Poland, Warsaw University of Technology, Faculty of Power and Aeronautical Engineering : MEchanical Engineering. BsC - 2013
RE: Array of Parts according to selection
Solution:
CODE -->
Set ArrayOfParts(ArrayOfParts_size) = SelectedParts.Item(1).Value
Sometimes You are not smart enough to find such dummy mistake bigglasses
Hi luka,
I am having trouble getting my macro to Activate a node in the tree so that I can edit it. Any ideas?
My code:
ActiveSel.Add cattree.Products.Item(i) 'Selects My product
CATIA.StartCommand "Expand Selection"
SendKeys "1"
SendKeys "~"
doesn't work
This also doesn't work:
ActiveSel.Add cattree.Products.Item(i) 'Select VSYS_CHASSIS product
hwndButtonOK = FindWindowEx(hwndExpSel, 0, "Button", "OK") 'Get handle to OK button
Foc = Putfocus(hwndExpTextbox) 'Put cursor in "Expand Selection" textbox
'SendKeys "1", True 'Choose single level expansion
lResult = SendMessage(hwndButtonOK, BM_CLICK, 0, 0) 'Press OK button
CODE -->
Sub CATMain()
AppActivate "CATIA V5"
Dim cmd As String
cmd = "wscript D:\sendKeys.vbs "
Call Shell(cmd)
End Sub
And D:\sendKeys.vbs code:
CODE -->
Set WshShell = WScript.CreateObject("WScript.Shell")
WScript.sleep 200
WshShell.SendKeys "c:Expand Selection" + "{ENTER}", True
WScript.sleep 200
WshShell.SendKeys "4", True
WScript.sleep 200
WshShell.SendKeys "{ENTER}",True
Works well to me
Before You run macro, please select any object from tree
Didn't work for me...
I am writing in catvba - does that help?
Ok...got it to work, partially (thank you) - but it only expands the tree - it does not activate the selected node as a double-click does.
Any ideas on that?
