Query in Sketch on Path - NX8.0.2
While creating sketch on path,the datum CSYS shows N1,N2,T1,T2.What is the meaning of that?
I have attached the image for your reference.
Thanks and regards,
Mathi Krishnan.
Thanks and regards,
Mathi Krishnan.
RE: Query in Sketch on Path - NX8.0.2
Or if you are use a 'curve' for the path and you reference some other face to control the Orientation then the the arrows will again indicate the 'Normal' and 'Tangent' directions, as shown below:
BTW, these 'N' and 'T' arrows can be referenced when assigning constraints while you actually creating your sketch, which is very handy when creating something like a Variational Sweep surface.
Anyway, I hope that helps.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
