12 psi pitot through 4.5" Pumper Outlet
68 static
44 residual
12 psi pitot
4 1/2" orifice
Using this Link
Does 1,569 look right to you because it doesn't to me.
44 residual
12 psi pitot
4 1/2" orifice
Using this Link
RE: 12 psi pitot through 4.5" Pumper Outlet
I come up with 1,737 usgpm.
I came up with the same thing and was curious as to why they differed so.
Apply pumper modifier: 1883*0.83 = 1563 GPM.
It seems they are right on. Probably just rounding differences.
Don't forget that per 291, you have to do the pumper modifier to the flow test data you get.
Travis Mack
MFP Design, LLC
www.mfpdesign.com
