Removing radii from imported model
I imported a stp model and need to remove all radii to allow be to add draft etc.
Is there an easy way to remove these?
Thanks in advance.
RE: Removing radii from imported model
Hello addenroy,
When I have to remove radii, I use the Remove Face feature. More about this can be found here.
Spoiler (on YouTube)
Hope this helps,
Best of luck!
CATIA V5R19 – user & trainer
ANSYS – beginner
I would like to correct the previous link: this is the one. bigcheeks
ANSYS – beginner
TibiX, Thanks - that did the trick,
A.
