Parts List
Parts List
Hello;
I have N8. When I make a drafting for an assembly, the PARTS LIST is only 1 rows with the quantity of all the parts and PC NO 1. In the properties/attributes of all the part the CALLOUT value is 1. What I have to do for have a complet list of all my parts (PC NO / PART NAME / QUANTITY)differents for every parts???
Best regard
Spaggiari
Best regard
Spaggiari
RE: Parts List
Can you please send us a snapshot of the assembly navigator tree and the part list in the drafting?
Are you sure that you have a proper assembly and not a single part file with multiple bodies?
Best Regards
Kapil
RE: Parts List
RE: Parts List
Thanks for rapid answer
Best regards
Spaggiari
RE: Parts List
It looks like a imported step file.Can you try a SELECT PART LIST right click and UPDATE PART LIST?
Kapil
RE: Parts List
Edit Parts List and you can choose what level of the assembly tree you want, then update.
“Know the rules well, so you can break them effectively.”
-Dalai Lama XIV
RE: Parts List
b)I try to change all the possible levels but nothing change after update!
Any ohter idea??
Spaggiari
RE: Parts List
Byebye
