EPANET age problem
EPANET age problem
EPANET age problem
I am currently working on the research project focused on the innovative residential sprinkler system influence on the water age in domestic drinking water system.
While using EPANET for age simulations, I have found, that it has made some errors in calculations. To be more precise: EPANET results show that the water age at specific node decreases, despite the fact that there is no demand at that moment and, also, there is no flow in the link that is connected to the node.
Maybe someone knows what could be the reason for this and, also, possible solutions for the problem.
Thank you in advance!
Kriss Malinovskis
RE: EPANET age problem
I have found the age function to work correctly
perhaps you could give more details
Hydrae
