Impingement Cooling
Impingement Cooling
Impingement Cooling
Does anyone have info on heat transfer coefficients for impinging air flow?  Ideally I'd like the HTC for impingement at a 90 deg angle with the finned side of a heatsink.  Thanks in advance.
RE: Impingement Cooling
No jets, holes, etc., just a fan.
Are we speaking of an air cooler ? If so, there is plenty of literature on the subject.
Yes, air.  Can you give one reference that is readily available?  Thanks.
