Typical coefficient of discharge for an airlift pump
Does anyone know where i can obtain a typical Cd for an airlift pump ? needs to be reference-able (if that is a word!)
I understand that there any many empirical formulas in circulation that use two phase flow etc however i need to find the head and flow rate (theoretical and actual) of an airlift when all i have is the actual flow rate, air pressure, outlet area and submergence (oh and assume water = 1000 kgm^-3). All of the formulas out there require inlet velocities etc which i do not possess.
I understand i would only get a rough figure however its better than nothing !
Thank you very much i appreciate it
RE: Typical coefficient of discharge for an airlift pump
I found one from 2003 which had some good reference material.
Independent events are seldomly independent.
With mixture of solid(S),gas(G) and liquid(L) I've used an article by G.F. Hewitt on Void Fraction, however, I do not have his book anymore for reference, so you'll have to research it in the library. This is the article you want if the mixture fractions are either S,G,L or G,L
