Sheet Metal query - NX7.5
How would create this bracket using Sheet Metal tool, only?
I am interested in the right side of the part (faces marked in yellow for evidence).
MZ7DYJ
RE: Sheet Metal query - NX7.5
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
you can try hem option also.(image attached)
Best Regards
Kapil
Yes, It does! Thanks a lot!
kapmnit123:
Thanks for your suggestion.
Hem Flange would give different results than the one that is expected.
I have created an Assembly on which I included 3 components:
1) The original one (created by me ; extension GI)
2) Mr. Baker's one (extension JRB)
3) Yours (extension kapmnit123)
I have intentionally altered the edge used for the Hem Flange in order to get a better visualization of the feature.
Mr. Baker's model is the one that works.
Thanks, again, both of you for your reply!
MZ7DYJ
But for standard cases perhaps it might give you something fast.
Have a good day.
Best Regards
Kapil
The green face should be collinear with the yellow one!
Your input on this topic is, again, welcomed!
MZ7DYJ
MZ7DYJ
Actually the flange is always created (unless you mitre the corners) normal to the face you attach it to (while creating the sketch of the profile the sketch plane used is the one normal to the edge path.
In your model the angle is a bit different than 90 degrees (please find the image attached).
You might think of using synchronous in that case to replace the end faces with the base faces.
Best REgards
Kapil
