Replacement Wood Truss Dimensional Responsibility
If you have a portion of a residential roof structure (standard gable wood pre-manufactured trusses) that was damaged and you want to order new trusses, who's responsibility is it to obtain the EXACT existing dimensions to order new trusses? Contractor, engineer, or truss manufacturer?
RE: Replacement Wood Truss Dimensional Responsibility
When you took on the job was that secified? If not, I'd give dimensions as close as possible and specify for the contractor and manufacturer to cooridinate and confirm.
