Bending moment and Shear stress limits on bolts
My problem is this: I have a flat plate and Object A (Object A: roughly 3 ft. x 2 ft. x 1ft. and 270 lbs.; flat plate: 1 ft. x 1 ft. x 1 in.). Obejct A is to be bolted to the flat plate so that it sits above the flat plate. Three bolts will be used in a configuration that fits within a 2 inch by 10 inch area (forming an isocoles triangle). However, I must leave about a 2.5-inch clearance in between the two components. Object A is now fixed in relation to the flat plate at a distance of about 2.5 inches, but the flat plate will be able to rotate freely about its X and Y axes. As the flat plate rotates, the connecting bolts will experience shear stress and a bending moment. I believe shear would be maximum at a 45 deg angle and the bending moment would max out at 90 deg. How can I fiugre out what bolts can withstand these loads? And I know there've been variations of the same type of problem previously posted, but I also would like to see or be directed to some calculations that could solve the problem. What is the material property of the bolts that determines the strength to withstand circumstances such as this? Thanks.
RE: Bending moment and Shear stress limits on bolts
http://www.hexagon.de
Distribute applied moment at bolt pattern centroid about x and y axes to convert to equivalent bolt tensile and compressive loads based on moment of inertia of bolt shank cross sectional areas about x and y axes w.r.t. bolt pattern centroid (conservative). Zero the bolt compressive loads, as these are plate contact.
Once individual bolt loads are obtained, you can check bolt equivalent combined tensile and shear stress for steel bolts as follows (conservative). This only checks fastener, not thread shear (stripping) stress if you have tapped holes. sigmavm = {[max(U Pi + FS C Pt, FS Pt)/Ats]^2 + 2.78(FS V/As)^2}^0.5, where U = torque uncertainty (1.25 to 1.30), FS = rupture or yield factor of safety for your project, C = bolt stiffness relative to joint total stiffness (0.35 for steel plates or 0.45 for aluminum plates is usually a conservative guess), Ats = bolt tensile stress area, As = bolt transverse shear area = 0.25 pi D^2 if shear plane in solid shank, or equals Ats if shear plane in threads, V = bolt applied shear force, Pt = bolt applied tensile force, Pi = bolt installation preload = T/(K D), T = bolt installation torque, K = torque coefficient (sometimes assumed 0.20 for dry installation or 0.15 for greased, for steel on steel), D = bolt shank nominal diameter. Once sigmavm is obtained for each bolt, compute bolt stress level R = sigmavm/St, where St = Stu if FS was for rupture (the usual analysis), or St = Sty if FS was for yield, Stu = bolt material tensile ultimate strength, Sty = bolt tensile yield strength. If bolt stress level R > 100%, the analysis indicates bolt is overstressed.
The reason no bolt material shear strength is listed above is because Ss = 0.60 St is built into 2.78 coefficient in above paragraph.
Bolt shear force should be maximum at 90 deg flat plate tilt if I understand your configuration.
Now moving on to your second post, because you're using standoffs (spacers, sleeves), bending stress on the bolt threads is not at all negligible unless you use very wide, stiff spacers and a relatively high preload, and plenty of thread engagement length in tapped hole. You'll need to figure out the moment, tension, and shear at the base or head of each bolt. You can then figure out the bending stress component on the bolt threads and add a bending stress term sigmab to the bolt combined stress equation mentioned in my previous post. Namely, sigmavm = {[max(U Pi + FS C Pt, FS Pt)/Ats + FS sigmab]^2 + 2.78(FS V/As)^2}^0.5.
If feasible, consider using a solid steel or aluminum isosceles triangular plate, or rectangular plate, of sizable footprint instead of the standoffs if you want to reduce some of your analysis difficulty. It could even be hogged out in the center to reduce weight. Otherwise, size your standoffs large to try to reduce the bolt bending stress component. Good luck.
