Help finding value in API 650
Regarding the Equivalent Seismic Design Force and the Vertical Seismic Force (E.6.1.3), is the Weff simply the combined effective impulsive and convective weights calculated per E.6.1.1? If not, where is this weight defined? Also, I cannot find the lateral acceleration coefficient A for the equivalent lateral force calculation.
Thanks!!
Thanks!!
RE: Help finding value in API 650
The "A" factor is not actually used as shown, that is the general relationship, and it is broken down into the impulsive and convective components using Ai and Ac as defined in E.4.6.2.
