Catia v5r19 cumulated dimensions
I have CatiaV5R19:
I'm trying to get cumulated dimensions to display as in the attachment. When I go to Tools / Standards / Drafting / Dimensions and in ANSI.xml category, in the Cumulate Dimensions section I can't get any of the display options to change in the right window when I click the up/down arrows. Some of the options don't display any picture to reference either, in the right window. Can anyone help me with how to use this dialog window?
RE: Catia v5r19 cumulated dimensions
Hello johnschwartz,
You can use the Cumulated Dimensions in the Dimensioning toolbar (Dimensions sub-toolbar) to create the desired result. More about this tool can be found here_1 and here_2.
It would probably be a good idea to modify some setting of the dimensions. Right-click it, and go to properties.
Hope this helps,
Best of luck!
CATIA V5R19 – user & trainer
ANSYS – beginner
