Does SW keep track of time spent.
Autocad has had a feature that keeps track of total editing time since the DOS versions. Does SW (2012x64 SP1.0) keep track of time spent?
Thank you for your time
RE: Does SW keep track of time spent.
Did anyone ever try to really use the 'editing time' records kept by AutoCAD?
Mike Halloran
Pembroke Pines, FL, USA
-handleman, CSWP (The new, easy test)
Chris
SolidWorks 11
ctopher's home
SolidWorks Legion
I don't think this is the answer you are looking for, but I thought I would post this in case some thing this will work for your needs as well.
Scott Baugh, CSWP
FAQ731-376: Eng-Tips.com Forum PoliciesBerry Plastics
Cad Admin\Design Engineer
GEASWUG Greater Evansville Area SWUG Leader
www.scottjbaugh.com
You may be able to track usage using the SolidWorks Jornal Files but that would require a script to copy the reg file out of the user's journal file folder or have them do a SolidWorks RX after each session which may waste more time than not tracking your users so harshly.
Unsure of Current Journal File location check the folowing Registry option
Run regedit
My Computer\HKEY_CURRENT_USER\Software\Solidworks\SolidWorks 2YYY\ExtReferences\SolidWorks Journal Folders\
This can be/should be customized if need be but is usually in My Documents. If you are not comfortable browsing your Registry Files *.reg
You can Search for "swxJRNL.swj" on your C: or Install Drive
"It's not the size of the Forum that matters, It's the Quality of the Posts"
Michael Cole
Boston, MA
CSWP, CSWI, CSWTS
Follow me on !w¡#$%
@ TrajPar - @ mcSldWrx2008
= ProE = SolidWorks
