multi-variables Regression
thread770-214997: Multivariable regression in Excell
Hi everyone,
I am trying to find the regression equation for a set of data with 2 independent variables using LINEST function in EXCEL.
I re-tabulated my data in order to use the LINEST function. The equation I would like to get is from the second order like this:
Y = c + a1*x1 + a2*x1^2 + b1*x2 + b2*x2^2
and like this as well:
Y = c + a1*x1 + a2*x1^2 + b1*x2 + b2*x2^2 + b3*x1*x2
I tried to use the same method used in this link but I could not get any results. http://www.eng-tips.com/viewthread.cfm?qid=214997#...
I have attached my EXCEL file, have a look please. http://files.engineering.com/getfile.aspx?folder=4...
May any one please help me with that?
Please give some explanation about how to get the coefficients such as the ones included in the referred thread =LINEST(Y1:Y10,B1:B10^{1,2,3,0,0,0,1,2,3}*C1:C10^{0,0,0,1,2,3,1,1,1},TRUE,TRUE)
I would like to mention something else: my original data has 4 variants Y=f(x1,x2,x3,x4) but I tried to make my question simple. Therefore, should I use the same method when dealing with more complex data?
Many Thanks
Alaa
RE: multi-variables Regression
The ^{0} trick wont work because you have zeroes in your data and 0^0 is undefined. Instead, just create the x1*x1, x2*x2 and x1*x2 columns and refer to them explicitly:
=LINEST(D3:D123,E3:H123,TRUE,FALSE)
or E3:I123 to include the x1*x2 term.
Remember to hit ctrl-shift-enter when entering the formula.
