chemical welding of polycarbonate
I have designed a plastic case such that a base plate snaps into place, but I need to chemically weld the two parts to ensure the final assembly doesn't come apart. What type of glue or compound should I be using? Any ideas or suggestions would be appreciated.
Cheers
Cheers
RE: chemical welding of polycarbonate
