Radial joint pattern in SAP2000
Does anybody know how to apply a radial joint pattern in SAP2000?
I'm modelling a circular slab on grade supporting a stockpile (cone shaped load). I've defined the structure but cannot assign a cone shaped joint pattern to the joints to get a cone shaped load since, even though I'm working on a cylindrical coordinate system, the joint pattern form only admits a linear Ax+By+Cz+D joint pattern, while I need Ar+D.
I'm dividing the circle into sectors and applying a different joint pattern to each of them, but this is a rough approximation.
Any ideas?
Any ideas?
RE: Radial joint pattern in SAP2000
http://www.eng-tips.com/viewthread.cfm?qid=264774
The solution given there is complex to apply.
Any other ideas?
