Set edge as reference
Hello all
I'm working on macro that will return length of selected linear object (edge, line, spline, etc..)
There are two approach to get object as reference
simply way - when object is selected from tree (asALine, isASplin etc..) or more complicated - when these same (or any other) object is selected from graphic window
here is the whole code:
CODE -->
Language="VBSCRIPT"
Sub CATMain()
Set partDocument1 = CATIA.ActiveDocument
Set part1=partDocument1.Part
set selection1=partDocument1.Selection
if selection1.count=1 then
set MeasuredElement1=partDocument1.Selection.Item(1).Value
'msgbox TypeName(MeasuredElement1)
isALine= Instr(1,TypeName(MeasuredElement1),"HybridShapeLine")
isASpline= Instr(1,TypeName(MeasuredElement1),"HybridShapeSpline")
isAConnect= Instr(1,TypeName(MeasuredElement1),"HybridShapeConnect")
if (isALine<>0) or (isASpline<>0) or (isAConnect<>0) then
set ref1=part1.CreateReferenceFromObject(MeasuredElement1)
else
newName= right(MeasuredElement1.Name,Len(MeasuredElement1.Name)-10)
if InStr(1,newName,"REdge")=0 then
msgbox "Select Edge or Line only!"
Exit Sub
else
Pozycja = InStr(1,newName, "None:(Limits1:();Limits2:());Cf11:())")
newName=left(newName,Pozycja+Len("None:(Limits1:();Limits2:());Cf11:())"))
newName=newName&"WithPermanentBody;WithoutBuildError;WithSelectingFeatureSupport;MFBRepVersion_CXR15)"
set ref1=part1.CreateReferenceFromBRepName(newName,MeasuredElement1.parent)
end if
end if
Set TheSPAWorkbench = partDocument1.GetWorkbench("SPAWorkbench")
set measurable1 = TheSPAWorkbench.GetMeasurable (ref1)
msgbox measurable1.Length
else
msgbox "Select only ONE element"
end if
End Sub
It works, but I'm wondering if there is any other way to set for example edge as reference without all those 'playing' with string newName
Thanks for all Yours replies.
Łukasz
LukaszSz. Poland, Warsaw University of Technology, Faculty of Power and Aeronautical Engineering : MEchanical Engineering. BsC - 2013
RE: Set edge as reference
Bellow is an example in a CATScript. Make a part with a pad inside and few holes and test it.
CODE --> CATScript
' Purpose: The macro will find the holes in a CATPart and will list them one by one in a message box
' Usage:   1 - A CATPart with Holes should be active
'          2 - Run macro
' Author: ferdo (Disclaimer: You use this code at your own risk)
Language="VBSCRIPT"
Sub CATMain()
Dim partDocument1 As Document
Dim part1 As Part
Set part1 = partDocument1.Part
Dim bodies1 As Bodies
Set bodies1 = part1.Bodies
Dim body1 As Body
Set body1 = bodies1.Item("PartBody")
Dim shapes1 As Shapes
Set shapes1 = body1.Shapes
dim selection1 as selection
set selection1=CATIA.activedocument.selection
selection1.clear
for i = 1 to shapes1.count
selection1.add shapes1.Item(i)
NEXT
'Loop to find holes
Dim xSelObj() As Variant
Dim xObj As Variant
Dim n as Integer
Dim myObj As AnyObject
Dim nCount As Integer
nCount = 0
		for n= 0 to shapes1.count
			  On Error Resume Next
			  Set myObj = selection1.FindObject("CATIAHole")
             			  ReDim Preserve xSelObj(nCount)
               			 Set xSelObj(nCount) = myObj
			  nCount = nCount + 1
		next
  ' Listing holes
Dim sList As String
Dim nI As Integer
'Loop for message
		For nI =0 To ncount-3
dim referenceX as reference
 Set referenceX = part1.CreateReferenceFromObject(xSelObj(nI))
 MsgBox referenceX.DisplayName
		Next
part1.Update
End Sub
Fernando
https://picasaweb.google.com/102257836106335725208
https://picasaweb.google.com/103462806772634246699...
