ASTM A656 grade 80 vs. ASTM A1018 HSLAS-F GR80
Hello all,
Just trying to figure out if I have ASTM A656 Grade 80 called out on the drawing but the 0.5" part is cut from ASTM A1018 HSLAS-F Grade 80, should I be concerned? The part is part of a weldment and is used in a dynamic (fatigue) environment. Are these different material specs interchangeable?
I have the same qestion for ASTM A572 Grade 50 and ASTM A1018 HSLAS-F Grade 50?
Thanks in advance
Thanks in advance
RE: ASTM A656 grade 80 vs. ASTM A1018 HSLAS-F GR80
