Standard with allowable stress for heat exchanger's nozzles?.
What is the standard with allowable stress for heat exchanger's nozzles?.
Fluid is Water or other with Temperature Range: 68-194 °F.
I have only API 661 which does not apply to this case.
Thanks in advance.
Thanks in advance.
RE: Standard with allowable stress for heat exchanger's nozzles?.
The Code is ASME VIII Div 1 and the Pressure design is 8 bar.
If it's an existing design, the allowable loads should be quoted on the design drawings. If not you might approach the manufacturer.
If it's a new design and you have no other source of allowable loads, I recommend agreeing Norsok values with the manufacturer.
