Swimming Pool as Fire Pump Water Source
I have a client who wishes to use a in ground swimming pool for the primary water source for a fire pump to serve the resort hose connections. The project is located within the Bahamas and besides the life safety issues, I can not find any code violations in using a swimming pool as a water source.
Does any here have any experience is such an issue?
Chris
Chris
RE: Swimming Pool as Fire Pump Water Source
how long will it take to refill?
and just trying to set it up for the use??
what happens when they drain the pool to work on it???
Excellent questions on the maintenance issues however since the fire pump is voluntary, I doubt the owner will mind but I will state my concerns.
Travis Mack
MFP Design, LLC
www.mfpdesign.com
My two cents... ;)
Mike McCann
MMC Engineering
