PMI data not showing on JT2GO
Hi everyone,
I created a simple block with some PMI data on it, just to test out JT2GO.
When the JT file of the block is opened on the JT2GO, it says it has PMI (the PMI column in the assembly tab as a green check mark). However, when i turned on PMI and toggled on multiple/single entity mode, no PMI is displayed. In fact, in the PMI tab, only the model views are present (I actually don`t know why they are there, but oh well)
Anyone knows how to approach this problem?
WIlson.
NX 7.5
WIlson.
NX 7.5
RE: PMI data not showing on JT2GO
in jttogo switched to the Pmi view?
I'm not quiet sure I understood what you said. Can you explain a little bit more?
Wilson
