UG NX - closed when running an static linear anlysis
Hello
When i tried to solve a simple linear static analysis in UG NX with integrated Nastran solver, I recieved an window"UG -closed abrubtly" .
How can i solve this problem.
RE: UG NX - closed when running an static linear anlysis
Take a look to the *.LOG file and *.F06 output nastran files located in the directoy of you study, there you will see the reason.
Surely you don't have defined the route to the solver NX NASTRAN, you need to define a minimum of data to allow NX AdvSim lo locate the FEA solver: Click on the study and Edit the SOLVER PARAMETERS, and there enter the solver parameters, or set to use instead the values of variables defined in the system:
UGII_NX_NASTRAN
UGII_NX_NASTRAN_VERSION
Go to FILE > UTILITIES > CUSTOMER DEFAULT > SIMULATION > NX NASTRAN > SOLVER PARAMNETERS and define there all you need to make the solver run, the changes you make here will be available for the new studies.
Best regards,
Blas.
Blas Molero Hidalgo
Ingeniero Industrial
Director
IBERISA
48011 BILBAO (SPAIN)
WEB: http://www.iberisa.com
Blog de FEMAP & NX Nastran: http://iberisa.wordpress.com/
Did you acquire the software legally?
Who installed it?
NX 7.5.5.4 with Teamcenter 8 on win7 64
Intel Xeon @3.2GHz
8GB RAM
Nvidia Quadro 2000
