Welding of AISI4140 to SA240 TP316L
Hello
I want to weld AISI4140 to SA240TP316L, Please advice me which electrodes I have to use
RE: Welding of AISI4140 to SA240 TP316L
The 4140 steel will be difficult to weld because of the carbon content (0.40% by mass). You will most likely need to use elevated preheat and PWHT, which would affect the corrosion performance of 316L base material. So, consider buttering the 4140 steel side of the weld joint first using one of the two electrodes mentioned above, PWHT the 4140 buttered material and then complete the rest of the weld joint to 316L using either electrode with no final PWHT.
