define Time Points in field output
I'd like to define Time Points in field output to reduce the size of the odb file as I am running a explicit analysis. I chose "specified using delimiters". There, one has to enter starting time, end time and increment. I am a bit unsure about what to put in increment. Let's say I write starting time=0.01, ending time=0.1 and I want 10 increments in between. Shall I write increment=10 or increment=0.01 ?
thanks.
thanks.
