din iso 2768 rad less 0.5mm
Hello all,
In din iso 2768 are tolerances defined from radii 0.5mm and up.
Simple question is: what about radii less than 0.5mm?
For example what tolerances to use for a radii 0.3mm?
Thanks in advance.
Pascal
Belgium, Europe.
RE: din iso 2768 rad less 0.5mm
Hello all,
Problem solved: one have to set the tolerances on the dimensions in the drawing for radii less than 0.5mm.
So for example R0.3+-0.05.
Pascal
Belgium, Europe.
