Getting time step from ODB using python
Hi there,
I have an odb from which I'd like to extract some data, namely a reaction force and some displacements. Here is a working part of the code (except for the Time1). The analysis is non-linear due to the material properties so I have to make various increments (around 60). I want to write to an output file Time.dat the different times (the increments, or the cum ulative increments) and to another file Results.dat the forces. If I remove the line ""Time1=lastStep.frameValue"" it works nicely, I get the forces in the different frames of the step, but I do not want to get the frames, I want to get the time step associated to the frame.I have looked at the scripting user manual but I do not seem to find what I need.
Any help would be appreciated,
Sincerely
import odbAccess
ForceFile = open('Results.dat','w')
TimeFile=open('Time.dat','w')
myOdb = odbAccess.openOdb(path='Job1.odb')
lastStep=myOdb.steps['Step-1']
for x in range(len(lastStep.frames)):
lastFrame = lastStep.frames[x]
Time1=lastStep.frameValue%%%Here must be the thing...
ReactionForce = lastFrame.fieldOutputs['RF']
TimeFile.write(Time1)
for v in ReactionForce.values:
if v.nodeLabel == 1:
ForceFile.write('%10.8E\t' % (v.data[1]))
myOdb.close()
ForceFile.close()
TimeFile.close()
RE: Getting time step from ODB using python
Quote (eng23bio)
Quote (eng23bio)
But there's just one time step. So, why even request Time1, if all you want is the step time?
CODE --> Python
CODE --> Python
Are you new to this forum? If so, please read these FAQ's:
http://www.eng-tips.com/faqs.cfm?fid=376
http://www.eng-tips.com/faqs.cfm?fid=1083
Hi IceBreakerSours,
thank you for your answer. Certainly the question was not very well formulated. There is one step with different frames on it due to the different increments. In the .sta file I get these results and I want to write into the file the column named Step Time/LPF or, equivalently, the increments of time. In the attachments there is a sta file and I want to get the 8th or 9th column on it.
Thank you again!
STEP INC ATT SEVERE EQUIL TOTAL TOTAL STEP INC OF DOF IF
DISCON ITERS ITERS TIME/ TIME/LPF TIME/LPF MONITOR RIKS
ITERS FREQ
1 1 1 5 3 8 0.0250 0.0250 0.02500
1 2 1 1 3 4 0.0500 0.0500 0.02500
1 3 1 1 3 4 0.0875 0.0875 0.03750
1 4 1 2 4 6 0.144 0.144 0.05625
1 5 1 2 3 5 0.228 0.228 0.08438
1 6 1 3 4 7 0.355 0.355 0.1266
1 7 1 4 4 8 0.545 0.545 0.1898
1 8 1 3 6 9 0.829 0.829 0.2848
1 9 1 3 2 5 1.00 1.00 0.1707
I found the problem. I was accessing lastStep.frameValue and I should access lastFrame.frameValue
Thank you again IceBreakerSours, your comment was very helpful to help see my error.
Cheers
import odbAccess
Time1=lastFrame.frameValue%%%Here was the problem. Now solved
TimeFile.write('%10.8E\t' %Time1)
myOdb.close()
ForceFile.close()
TimeFile.close()
