Cycle through PPR tree Macro
Hi everyone,
I am looking for a macro that scans the PPR tree and writes down in a (dynamic) array the PARTS of a MAINPRODUCT.
My problem scenario is to move level by level all parts of the mainproduct but i want to do it through a dynamic array.
I made an attempt with a for loop in order to create the array and is the following:
Sub CATMain()
Set productDocument1 = CATIA.ActiveDocument
Set product1 = productDocument1.Product
Set products1 = product1.Products
Dim partcount As Integer
partcount=product1.Products.Count
msgbox "The number of parts is "&partcount&". Please click OK to continue."
Dim ObjArray(999) As Object
For i = 1 to partcount
Set ObjArray(i-1) = products1.Item(i)
'Set ObjArray(0) = products1.Item(1)
'Set ObjArray(1) = products1.Item(2)
'Set ObjArray(2) = products1.Item(3) 'At this case there are 6 parts
'Set ObjArray(3) = products1.Item(4)
'Set ObjArray(4) = products1.Item(5)
'Set ObjArray(5) = products1.Item(6)
Next
Set move1 = ObjArray(i=4).Move
Set move1 = move1.MovableObject
Dim arrayOfVariantOfDouble1(11)
arrayOfVariantOfDouble1(0) = 1.000000
arrayOfVariantOfDouble1(1) = 0.000000
arrayOfVariantOfDouble1(2) = 0.000000
arrayOfVariantOfDouble1(3) = 0.000000
arrayOfVariantOfDouble1(4) = 1.000000
arrayOfVariantOfDouble1(5) = 0.000000
arrayOfVariantOfDouble1(6) = 0.000000
arrayOfVariantOfDouble1(7) = 0.000000
arrayOfVariantOfDouble1(8) = 1.000000
arrayOfVariantOfDouble1(9) = 0.000000
arrayOfVariantOfDouble1(10) = 15.000000
arrayOfVariantOfDouble1(11) = 10.000000
move1.Apply arrayOfVariantOfDouble1
End Sub
No matter what is the value at { Set move1 = ObjArray(i=4).Move } the result is to move always the first part.
I would be very pleased if you could suggest me a code or help me fix mine.
RE: Cycle through PPR tree Macro
CODE -->
Dim ObjArray(999) As AnyObject
or
CODE -->
Dim ObjArray(999) As Product
LukaszSz. Poland, Warsaw University of Technology, Faculty of Power and Aeronautical Engineering : MEchanical Engineering. BsC - 2013
