power outage; personal settings reset
On Thursday, our shop experienced a power outage. Now, I've found that all of my keyboard assignments, and settings in the options menu have been reset. Also, a couple icons that I had assigned to macros in toolbars have been replaced with plain text.
Is there any way I can fix this? Is there a configuration file somewhere that may have been corrupted that I can retreive from backup? This is truly awful and will take ages to fix if not.
Nick
Light structural commercial aircraft parts
PCDMIS 4.3 CAD++, CATIA V5 R20
APM Consortium Inc.
Cambridge Ontario, Canada
RE: power outage; personal settings reset
Really? Nobody has ever had the UI reset or do weird things? 'Course it happened to me!
APM Consortium Inc.
Sorry for late response, no internet connection for a while...
There is no way to recover your custom CATSettings if you didn't save them before...usually you have to back-up them when CATSettings are "fresh" and you finished your customization...
In the future you can use in a CATScript the code bellow. This is just the part of the back-up, it can be improved by writing the code to copy back on the right CATSettings location....(if someone wish).
CODE --> CATScript
Option Explicit
Sub CATMain ()
Dim input, sLF
'~ create input box which is in fact the path to CATSettings files
sLF = Chr(10)
 input = InputBox ("You can create a back-up copy of your CATSettings and CATPreferences files when CATIA is working fine. The path to your CATSettings and CATPreferences files is bellow. Bach-up is in c:\Temp\  folder", "Find user CATSettings folder", CATIA.SystemService.Environ ( "CATUserSettingPath") )
If input = "" Then
	Exit Sub
End If
'~ Create a Windows Shell object
 Dim objPath, objShell, strPath, strPrompt
Set objShell = CreateObject( "Shell.Application" )
Dim objFSO,  Newfolder2, filesys, Newfolder1
Set objFSO = CreateObject("Scripting.FileSystemObject")
'~ create Temp folder if not existing
If  Not objFSO.FolderExists("c:\temp\") Then
   Newfolder1 = objFSO.CreateFolder ("c:\temp\")
End If
Dim UserName, objNet
Set objNet = CreateObject("WScript.NetWork")
Newfolder2 = "c:\" & "temp\" & "CATSettings_Back-up " & objNet.UserName
'~ Delete the previous BACK-up CATSettings folder if existing
If   objFSO.FolderExists(Newfolder2) Then
   objFSO.DeleteFolder(Newfolder2)
   End If
'Create the folder (again) to have the latest version
objFSO.CreateFolder Newfolder2
' copy files from one folder to another
        Dim sOriginFolder, sDestinationFolder, sFile, oFSO
Set oFSO = CreateObject("Scripting.FileSystemObject")
sOriginFolder = input '
sDestinationFolder = Newfolder2
For Each sFile In oFSO.GetFolder(sOriginFolder).Files
If Not oFSO.FileExists(sDestinationFolder & "\" & oFSO.GetFileName(sFile)) Then
oFSO.GetFile(sFile).Copy sDestinationFolder & "\" & oFSO.GetFileName(sFile),True
End if
next
End Sub
Fernando
https://picasaweb.google.com/102257836106335725208
https://picasaweb.google.com/103462806772634246699...
