Plastic selection
Plastic selection
What would be my best choice to select a plastic material matching the following requirements, please:
• Operation temperature (continuous): –65°C to +125°C.
• Specific gravity: 1.6 or less.
• Water absorption, 24 hours, %: less, than 0.09.
• Friction coefficient on steel, static: 0.15 or less.
• Wear resistance: 1000,000 cycles test.
• Major colors (black, white, green, red, yellow, orange, blue) availability.
Thank you.
Thank you.
RE: Plastic selection
If outdoors then doesn't it need UV resistance?
1. No contact with solvents.
2. UV resistance not needed (indoor, low light).
Thank you.
I assume colorants can be added to all of them.
Also too: can I glue 2 parts of the same material together? I know for PTFE I can, if I etch the surfaces.
