Seismic source between A and B
Assuming that per soils report the seismic source is between A and B,is it possible to interpolate the values of seismic source A and B to come up with a reasonable input value?.
RE: Seismic source between A and B
Use the worst case for the seismic factors. The factors are best guesses anyway, generated by geologically limited time data. Do not try to cut corners with seismic loads, ever.
Mike McCann
MMC Engineering
