API 614 Anunciator System (Is it in Local or in DCS?)
Im currently working on an API 614 4th ed lube oil system and one requirement from Client is for it to have a "First Out Annunciator" (Para 6.3.7 API 614 4th.).
Could somebody advise if what is the purpose of this annunciator?
Does it have a separate panel in the local near the skid for the lamps such as alarm , reset , running etc?
Is it also possible to have the annunciator system in DCS instead of local?
Thanks in advance.
Tilas
RE: API 614 Anunciator System (Is it in Local or in DCS?)
The purpose of the annunciator is to let you know what goes wrong and yes you can place it where ever you want. Manytimes it is local because when you start the pump you have someone there, but you could put it in a computer system if you want.
Want to know the do's and don'ts of Eng-Tips? Read FAQ731-376: Eng-Tips.com Forum Policies.
English not your native language? Looking for some help in getting your question across to others or understanding their answers? Go to forum1529: Translation Assistance for Engineers.
