ASME Data Reports
ASME Data Reports
Currently installing ASME Sec 1 Boiler in Canada Under our ASME “S” Mark. Boiler is being supplied by US based Engineering Contractor. They will provide master data report P3A including name plate. All boiler parts have been supplied by several US based ASME certified contractors. Question 1. Convection loose coils supplied by US fabricator P4 supplied is name plate required? for loose parts. Question 2. Loose coils shipped to Canada & assembled in ASME certified shop P3 supplied? Is name plate required? for this assembly. Question 3. Boiler crossover piping (Boiler Proper) P4 supplied by same contractor as loose coils can these be on the same name plate as the coils? Question 4. ASME Code break is located @ the first flange off the boiler there are pipe spools that fall under boiler proper&
have been supplied by different fabricator P4 supplied is name plate required? for these spools.
