Altitude - Density Altitude
Hello all. I am trying to understand the difference between altitude and density altitude. The only difference is that density altitude depends on my position's current air temperature and altitude does not?
If my position's current air temperature is increased, then the density altitude is also increased, but the altitude remains fixed. If my position's current air temperature is decreased, then the density altitude is also decreased, but the altitude remains fixed. I am right?
According barometric formula of wikipedia (http://en.wikipedia.org/wiki/Atmospheric_pressure#...), the altitude depends on my position's current atmoshperic pressure, current seal level atmospheric pressure and current sea level temperature.
According wikipedia (http://en.wikipedia.org/wiki/Density_altitude#Calc...), the density altitude depends on my position's current atmoshperic pressure, current seal level atmospheric pressure, current sea level temperature AND MY POSITION'S CURRENT AIR TEMPERATURE.
Have I understood well?
Also, I have created two scripts on matlab which calculate altitude and density altitude. Here are the codes and two simple running of them. Tell me your opinion:
Altitude:
Density Altitude:
Soon, I will buy a weather multimeter. Its instructions say: The DENSITY ALTITUDE screen is calculated from the absolute values of station pressure, relative humidity and temperature. And my mind is confused. Why it depends on relative humidity? What formula it uses?
Thank you in advance.
Altitude:
CODE --> Matlab
fprintf ( 1,'Hello, I will calculate your altitude.\n' );
cslt=input('Please, give me the sea level temperature (degrees C):');
fprintf ( 1, 'Thank you.\n' );
cslap=input('Please, give me the sea level atmospheric pressure (mb):');
cpsap=input('Please, give me the atmospheric pressure of your position (mb):');
alt=8.31447*(cslt+273.15)*log(cslap/cpsap)/(9.80665*0.0289644);
altf= alt*3.2808399;
fprintf('Your altitude is %d m or %d feet\n', alt, altf); CODE --> Matlab
>> altitude Hello, I will calculate your altitude. Please, give me the sea level temperature (degrees C):17 Thank you. Please, give me the sea level atmospheric pressure (mb):1017.9 Thank you. Please, give me the atmospheric pressure of your position (mb):999.9 Thank you. Your altitude is 1.515332e+002 m or 4.971562e+002 feet >>
Density Altitude:
CODE --> Matlab
fprintf ( 1,'Hello, I will calculate your density altitude.\n' );
ts=input('Please, give me the sea level temperature (degrees C):');
ps=input('Please, give me the sea level atmospheric pressure (mb):');
tm=input('Please, give me the temperature of your position (degrees C):');
pm=input('Please, give me the atmospheric pressure of your position (mb):');
da=145442.156*(1-((pm/ps)/((tm+273.15)/(ts+273.15)))^0.234969);
dam= da/3.2808399;
fprintf('Your density altitude is %d m or %d feet\n', dam, da); CODE --> Matlab
>> Density_Altitude Hello, I will calculate your density altitude. Please, give me the sea level temperature (degrees C):17 Thank you. Please, give me the sea level atmospheric pressure (mb):1017.9 Thank you. Please, give me the temperature of your position (degrees C):23.5 Thank you. Please, give me the atmospheric pressure of your position (mb):999.9 Thank you. Your density altitude is 4.146678e+002 m or 1.360459e+003 feet >>
Are you ready for the future?
RE: Altitude - Density Altitude
Quando Omni Flunkus Moritati
altitude is the physical vertical position. density altitude is an estimation of altitude based on a canonical model of the atmosphere as a function of altitude. There are a multitude of different models of the atmosphere; last I checked, there were at least 4, each with slight variations in parameters. Since these are all models, they cannot account for all possible atmospheric conditions, so the estimated altitude can be quite different than reality. There is an apocryphal story that a bunch of F-111 Wild Weasels crashed during the Vietnam War because their barometric altimeters were grossly different than reported by their radar altimeters.
total pressure is a function of the partial pressures of all the constituent gases, including water vapor:
http://en.wikipedia.org/wiki/Partial_pressure
TTFN
"density altitude" is saying (IMHO) that the density of the local atmosphere is equal to such and such altitude given a "standard" atmosphere (and not height above the ground).
altimeters work on local air density. when altitude is critical (eg landing and takeing off) the altimeters are tuned to the local current density (as reported by the control tower).
of course radio altimeters don't need this correction.
personally, i wonder about code that says "Hello, I will calculate your density altitude." ... doesn't sound very professional (IMHO).
But I want to focus on three subjects:
1) If density altitude depends on humidity, then why wikipedia's formula doesn't use this? http://en.wikipedia.org/wiki/Density_altitude#Calc...? Maybe because it is an approximate formula?
2) What is the relation between oxygen and density altitude? Does density altitude give us information about the percentage existence of oxygen in our position? Or it is only depends on altitude?
3) What similarities I will feel if I am in 2.000 m altitude and 2.000 m density altitude?
2) Depending on what you think you mean by "percentage existence of oxygen", yes or no. Since all of the components of air will closely enough follow ideal gas laws over any aerodynamic aviation range of altitudes the percentage of oxygen relative to other components by volume will not change with altitude. That is to say, air is about 78% Nitrogen, 21% Oxygen, 1% Argon, 0.3% Carbon Dioxide and the rest is "other stuff" at any altitude.
3) It entirely depends on how the 2000 meter density altitude is achieved. Look at the "Density altitude calculation chart" in your wiki article to understand why.
This is repeated in the Pilot's Handbook: http://www.faa.gov/regulations_policies/handbooks_...
TTFN
3) sounds like you're missing the point ... at 2000m physical altitude the density altitude can be quite different maybe +-200m depending mostly on the local temperature, and the local weather (high or low pressure systems), and to a lesser extent on a bunch of other factors.
There are 5 or 6 altitude definitions, look in FAA-H-8083-3A Airplane Flying Handbook and FAA-H-8083-25A Pilots Handbook of Aeronautical Knowledge and it will explain it all (available on the www).
In theory, there is no difference between theory and practice; experience suggests that in practice, there is.
