Gas line corrosion - Pics
Dear mates,
Pictures were taken from a pipe sample, it belongs to 4" CS-HP (90 Barg) gas line.
Background and findings : no SRB reported, no corrosion inhibitors injected, water was found inside the line, CO2 contents < 3%.
I'm thinking in Organic acid corrosion produced by APB colony.
Mitigation measure ??
Thanks in advance for any input you can have.
RE: Gas line corrosion - Pics
Steve Jones
http://www.linkedin.com/pub/8/83b/b04
All answers are personal opinions only and are in no way connected with any employer.
Thanks for you input about how to prevent MIC.
Two facts to think about MIC : localized corroded area was found in a straight part of the line, so no turbulent flow there and the statement in API 571 here below ( see photos).
API 571 - 4.3.8.5 Appearance or Morphology of Damage
b) Damage is often characterized by cup-shaped pits within pits in carbon steel.
Regards.
Steve Jones
Aaron Tanzer
www.lehightesting.com
Plymouth Tube
Thanks for the inputs.
