Yet another LTB question
Don't want to get into theory...very specific question here. Have a metal building with purlins on top of main frames- presumably only minimally connected to the top flange of the main frame beams at about 4 feet oc. Thinking that the unbraced length for positive flexure (top flange in compression) would be 4 feet. If I were to weld plates to the webs at each purlin location (connecting bottom flange to top flange), would the unbraced length for negative flexure at the columns and at center for uplift match the unbraced length for positive flexure? I'm thinking no, since translation/rotation of that bottom flange would be dependent on the connection between the purlin and the top flange of the beam.
RE: Yet another LTB question
BA
thread507-321425: Beam Lateral Bracing
I will try to find the research report which I remember.
Dik
and Yura's AISC Engineering Journal Fundamentals of Beam Bracing
We can summarize that
1. Lateral brace can be provided through one or two of the options
1) Brace the flange subject to compression directly OR
2) Prevent twist of the cross section.
2. Secondary beam pin connecting to main beam locating within the one-third depth of the beam web that is closest to the compression flange can be considered to provide a direct brace.
3. Transverse stiffening can be provided to prevent twist and transfer the bracing effectiveness from a properly attached floor system to the compression flange
Please refer to attached PDF file for details
anchor bolt design per ACI 318-11 crane beam design
http://www.civilbay.com
It is stated or implied in the reference which amec gave that bracing needs to be on the loaded flange, e.g. top or tension flange in a cantilever with gravity loading. It would follow that for uplift of a roof beam which is loaded on the top flange, the purlins would provide bracing, as they are connected to the tension flange. The principle is that tension flange loading acts to self correct any tendency of the opposite flange to translate. Comments?
If gravity load were suspended from the beam, lateral torsional buckling would occur at a higher load, but it could still occur. "Theory of Elastic Stability" by Timoshenko and Gere takes this into account.
BA
