Perpendicularity axis to axis
Please ref to the attached figure, the perpendicularity tolerance zone is two parallel planes that are .002 apart or a .002 diameter cylinder ?
The hole could slant to any direction, so I believe a cylindrical tolerance zone will be reasonable. How do you think ?
Season
Season
RE: Perpendicularity axis to axis
If you are fine with both axes tilting to any direction within specified limit, cylindrical tolerance zone is much more reasonable choice.
Season
Frank
