Circuit that would output 5 volts
I have a pressure sensor that needs 5 volts, and I have 12 to 13 volts available in the car. Is there a circuit I can put together that can deliver 5 volts.
RE: Circuit that would output 5 volts
Use a USB charger? But that might be 4.5V. How much current do you need?
like .1 amps .... it needs to be very close to 5.0 volts, any variation and it throws the reading off
Found this on Amazon.
Terry
KI6FCI
If this device is not specifically for automotive use you may consider some type of input protection across the input. Possibly a Zener diode. You can get some nasty load dump surges from an automotive alternator.
Bill
"Why not the best?"
Jimmy Carter
7805 data sheet will have a circuit you can build easily. LM7805
