need electrical circuit to monitor sensor
I have a sensata pressure sensor that outputs a voltage. I want to monitor this pressure transducer from inside my vechile. Have a spreadsheet that does a linear equation takes the voltage and makes it into a pressure (PSI), which is linear in nature.
Want to put together some circuitry that would take the voltage then out put to a display the PSI pressure. 2 digits would be enough seeing as the pressure never goes over 60 PSI.
Any help greatly appreciated.
RE: need electrical circuit to monitor sensor
There's this: https://www.sparkfun.com/products/11225 assuming you want it to go to a laptop, since you have a spreadsheet
or you can get https://www.sparkfun.com/products/11741 and do the math in the Arduino and display it on the LCD display. But a display can be had for less: http://www.ebay.com/itm/New-3-3V-0-96-128X64-OLED-... The Arduino is capable of quite a bit of processing, since variants of it are used for autopilots and inertial navigators.
That's assuming you weren't really going solder together something.
TTFN
I can solder no problem. I was thinking more like some littel process with an led that I could package and put in the dash area of my van.
The Arduino with the display shield would be quite compact, possibly a bit of an overkill. But if you want to display pressure in the correct units, you'll need at least something like that, both the calculation capability and the display capability.
TTFN
