Changeable pressure surface issue
I am modeling a seal with hyperelastic oring. I've applied a pressure to the oring from the gas side. But under the pressure rubber strongly deforms, so the surface to which the pressure is applied should also change.
My question is: is it possible (and if yes - how?) to apply pressure to changeable surface which takes into account model deformation?
